Hey guys, i need ur advice on a ported box, it's my first time doing this so don't laught lol. My subwoofer is Alpine swr-12420.
Subwoofer specs:
frequency response: 24-200 Hz
power handling: 300-600 watts RMS (300 watts per coil)
peak power: 1,800 watts
sensitivity: 85 dB
top-mount depth: 6-3/8"
sealed box volume: 0.65-1.25 cu. ft.
ported box volume: 1.0-2.0 cu. ft.
I'm gonna wire it on 2 ohms and my amp can hit 900w rms @ 2 ohms stable. The owner's manual has this specs for the box
This is what i came up with, i need an advice if it's okay or not
Thanks in advance.
Edited by SethBv
whats up man this is a good point to start for a single 12. from what i noticed from the more advanced members is when you are running more power than rms on ported boxes you shrink the internal box volume a little so the sub can handle the additional power without bottoming out. for a faster response you may want to directly message some of the guys who are on teams/compete as they have the build experience on more boxes or try the chat a lot them hangout there. stay bumpin
As i said, i have never done this before, so i used that program cuzz it gives me the cutting lenghts too so i have a lower chance of messing it up. Anyways, how many db's do u think i will hit with it? I'm not building it for spl only, i want both SPL and SQ, so 33hz should be ok right? :)
Well, the best way to learn is by doing :drinks: Nobody can tell you how loud your system is going to be because too many things play a factor in it. Anybody who even guesses is literally just making a number up off the top of their head.
33hz should be a fine tuning
The program most people use is Torres Box Building Calculator. It's a free download here on the forum and is much more accurate than the one you used
Edited by DRauck
2011 Honda CR-Z Mugen
12" Kicker SoloX Subwoofer
Rockford Fosgate t20001bd
Pioneer AVIC-X930BT Head Unit
Build Log
I would do something like 1.75 cubic feet and a single 4" aeroport :)
I made a google sketchup 3d model with those dimensions and the port (L2) has a pretty big gap..is it okay or should i make it smaller?
nevermind, technical error (dimension missread lol)
problem fixed :)
Edited by SethBv
  • Who's Online   1 Member, 0 Anonymous, 1367 Guests (See full list)
