DC Sound Lab
you can so run the wires from each coil to bolts on the side of the box and wired them down to what ever ohm load from the outside(if that makes sense)
well what i do now, i put 1 wire from each terminal to the side of the box (usually bolts) and wire it externally into parallel or series, so if you want to change it, you dont have to pull the sub out.
same thing as said above^^^
Edited by ChevyBoy95
i do know you can wire out side of box. but this will be only run in parallel(i can only fit on sub in location...no wall yet) and if i was going to add another i would make new bot and then could change where i wire them.
2 8s wont fit 1 barely does if you trim it down. put them to bolts like stated above or solder them together to a single run to your amps outputs
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
:good: yep
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 5023 Guests (See full list)
