DC Sound Lab
xl 15 terminal question
well what i do now, i put 1 wire from each terminal to the side of the box (usually bolts) and wire it externally into parallel or series, so if you want to change it, you dont have to pull the sub out.
same thing as said above^^^
Edited by ChevyBoy95
i do know you can wire out side of box. but this will be only run in parallel(i can only fit on sub in location...no wall yet) and if i was going to add another i would make new bot and then could change where i wire them.
2 8s wont fit 1 barely does if you trim it down. put them to bolts like stated above or solder them together to a single run to your amps outputs
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
:good: yep
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1724 Guests (See full list)
