Have you checked the resistance of ALL your power and ground wires? If there is no load but there is a ton of resistance in the line, the voltage will be normal but if you load the wire down and there is resistance, it will drop voltage since you are basically squeezing the power.
Since i have had this happen to me so many times, i always run my wires and take my TPI 440 and test resistance (but a normal DMM works as well) any run that is greater than .2 ohms in resistance needs to be redone. I always run it so that the positive of the wire coming from my alt, i test it to the positive of my battery. When checking resistance make sure you NEVER cross a positive lead to a negative lead. If you do this you will fry your meter and possibly melt the probe wires.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
i also forgot to put when i first put the new run of 0 in it worked fine for prolly a week. it just started all the sudden today out of no where. ive been doin audio for over 10 years this is the first time this has happened also first sony amp i ran. i should jst burn the amp i think its my honda rejecting the pos amp
2001 gmc seirra
5.3 auto 3.73 locked rear, long tube headers, offroad y pipe, duals, cai, black bear tune, 2/4 drop, 22s, rockford fosgate mods and highs and 4 ab hd 15s and a ab 750.1
1995 civic
1.5 auto slower then hell, dropped on coil overs, ex hub caps, 2 12 trunk, have 450 bucks in the car and gets 35 mpg
1992 s10
being bagged, shaved, and small stereo. right now a pile of parts
any other ideas postem up ima work on it again tonight till it is fixed
2001 gmc seirra
1995 civic
1992 s10
I thought of something else but im sure you are more than smart enough to not do this but ill chime in anyway. Are your wire ends stripped back enough so that the screw comes down on the bare wire and not any insulation? I fixed my friends truck and the jackass shop he went to put the wire in the distro without cutting enough of the wires jacket off. nea.gifOther than that i really dont know what else could cause a problem other than that resistance in your wires. Just start there and work from there, report back when you complete it so i can help you from there.
Gonna go out on a limb and say it is a bad battery or a resistance problem. Reason I think so is because a short that would pull a battery from 12.8 (floating) to 6 volts would have started a fire before you had the time to measure 6 volts. So, I rule out the amp too.
  • Who's Online   0 Members, 0 Anonymous, 1743 Guests (See full list)
