If you would actually do this a Rockford T2500-bdcp would be an obvious choice.
i already have the subs.. just tryng to find the right amp.
Run the RF 2500.1 and go ported. HX2's sound fantastic ported.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Do you guys think I should go ahead and get a bigger alternator. If so what size. I've heard its 70 amps per 1000 watts. So like a 220bigger should do right??
If you get a good alternator from a quality alternator company then a 270amp or 300amp alt will do, with a few batts.(2-3)
