Im showing for a single port, 15.5 high 5 wide and 20.5 deep, tuned to 35.
My plots are peaking huge, DB/HZ @ 1m peek is 44hz @ 121.6 db - 35hz @ 117.2
TermPak is pretty good at predicting but like always it will change as the postion in your car changes.
My last post before this one has the tweaked Final dimensions. 38 wide 22.5 deep and 17 tall. 3" diameter port that's 10.05 inch deep. so by what your saying, my port is wrong? if so what should it be now with the dimensions i just gave you and tuned to 33-34 HZ Thanks. PS its a single middle port. one port for 2 subs.
New box diams, were looking at 710cu inches of port, 15.5" x 3" 14.64 inches long
Plot is a lot smother peeking at 121.4 @ 41.3 hz and port velocity, looking at 18.2 m/s @ 32hz max.
Be sure to use a 45 deg. router bit on your port mouth and both sides of the port walls on the inside.
with this design you are nominal plus 5.13 db 1w per meter
Thank you for you help. So what I have now will work good with the 14.64 inch deep port? Will play lows and music good as a daily driver... not looking for SQ more on the loud side. Oh and the port is not an L port right? it just goes straight back?
Strait back, in the middle of the box to act as braceing as well
-Angel
I still think the port is too small...I'm just not a fan of small ports. Unless you can get 8ft^3 or more before sub and port displacements, I think you'll be sacrificing output in the end unless you're running a good deal more than rated power.
Edited by RAM_Designs
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
Yes that sounds right but it says not to give these subs anymore than 2.9 cubes each for best performance and right now they are getting. 3 or slightly more I'm am new at this shit so I may be wrong. As long as it bumps good I'll be happy.. I already started on the box with the 38w dimensions so now it's just the port that could make a big difference
I will have to agree with ram on this one, regardless of what the specs say the recomended box space and port are there so someone can build it and have some results without it sounding like complete ass.
If you want to work with port tuneing try making the port a drop in port so you can tune and remove the port if needed.
-Angel
Edited by Angel187
-Angel
-Angel
Yeah i think its too late i just got back from putting the port on.. :( I dont know how to make a drop in port anyway.. i heard that external ports work well but again no clue on how to design one.
-Angel
I'm building an external port box as i type. I'll post the pics later on.
-Angel
-Angel
ok cool
