Well?
I have my headunit in my bedroom right now, I performed the RCA Grounding "fix" and will check it out tomorrow morning when I wake up. Can't do it now, my parents room is right next to the garage, and my car is in the garage.
i had the same problem with my kenwood i got the ground loop things from ebay cleaned it right up i decide to do that because it the wires came loose off my rcas and fell off and i had to take my radio out again it prolly wouldnt get done for a while lol im a lazy mexican
Good stuff man. As I said above, I did the "fix" but even if it does fix it, I'm going to stop at my radioshack after work and pick up two of the ground loop isolators.
Thanks for your input guys!
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
Just so you are aware, ground loop isolators arent a 100% guarantee to fix your whine you are hearing. They help but dont eliminate all the noise.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Yeah I know, I've been doing some reading up on them. I'm just trying to fix this back to the way it was....playable.
First System
Welp, put the headunit in with the grounded RCAs and the problem is now completely gone! Also seems to help the little bit of fuzzy sound I had before this all happened!
Thanks for your help guys, I REALLY appreciate it. Looks like I have to go back to bestbuy and return those RCAs.
Again, thanks a ton!
First System
Glad you got it fixed and don't use ground loop isolators they take away a good bit of your pre-out voltage from my xp, and result in you having to up your gain to compensate, and to me they seemed to take away from the punch from the music.
The HU ground is the best route over the Isolator.
¿ǝɯɐƃ ǝɥʇ
Cool. I didn't have the time to stop there after work but it sounds better than ever now and I am very pleased with the outcome and that it was a free fix!
Appreciate all the help guys..I know I can always get help on here.
First System
  • Who's Online   0 Members, 0 Anonymous, 532 Guests (See full list)
