lowpt Posted November 4, 2011 Author Report Posted November 4, 2011 I got a heck of a deal on that hood, 200 bucks!! As for the stuff hanging down, it is spider webs. I had it set up with spiders and webs for the show but, had to take some of it up to pull into the lane.
Purplehaze Posted November 4, 2011 Report Posted November 4, 2011 I got a heck of a deal on that hood, 200 bucks!! As for the stuff hanging down, it is spider webs. I had it set up with spiders and webs for the show but, had to take some of it up to pull into the lane. No way! $200 DAMN where did you steal that from? Isn't that a PTeazer hood? Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
lowpt Posted November 4, 2011 Author Report Posted November 4, 2011 No way! $200 DAMN where did you steal that from? Isn't that a PTeazer hood? Yep, someone wrecked their show car and I ended up with the hood. I am on the lookout for a steel s10 cowl hood. I want to cut the cowl off and put it on my stock hood.
down2earth Posted November 4, 2011 Report Posted November 4, 2011 Awesome work man keep it up my 1949 ford f-1 build log http://www.stevemead...running-boards/ my 1981 crew cab dually bagging and body dropping http://www.stevemeadedesigns.com/board/topic/132672-bagging-and-body-dropping-a-81-crew-cab-dually/page__st__100
lowpt Posted November 5, 2011 Author Report Posted November 5, 2011 Awesome work man keep it up Thanks!!
Purplehaze Posted November 6, 2011 Report Posted November 6, 2011 No way! $200 DAMN where did you steal that from? Isn't that a PTeazer hood? Yep, someone wrecked their show car and I ended up with the hood. I am on the lookout for a steel s10 cowl hood. I want to cut the cowl off and put it on my stock hood. So does that mean if you do that, then you would sell me your hood for your money back? Actually I was thinking the same thing, except I thought about glassing up a new hood next summer! Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
chronic2001 Posted November 6, 2011 Report Posted November 6, 2011 Looks awesome... Nice work very clean. Pioneer deh-8300UB 6- Image Dynamics CSX6.5v2 4-Image Dynamics XS-28 tweeters 4-Sundown Audio sa8v2's 1-Sundown Audio SAX-200.4 1-Sundown Audio SAX-1200d 1-Mechman 270a alternator 1-XS Power D3400 under hood Second Skin Damplifier Pro Deadener Kicker & Knukoncept 1/0 wiring Big 3 upgrade
RMac18 Posted November 6, 2011 Report Posted November 6, 2011 Nice looking build, doors came out really nice and I like the layout you went with for the truck.
lowpt Posted December 3, 2011 Author Report Posted December 3, 2011 I have had a problem with voltage drop since the new equipment went in. I knew I needed to add a second battery to help with my power needs. I was planning on just adding a second Optima in the rear but, as luck would have it I came across a good deal on a XS Power D2700. I want to mount it under the car with the air tank. After taking some careful measurements I found that the battery just isn't going underneath the car right now. So, I have decided to install it inside the car until I redo the rear suspension setup. I built a box out of 2" x 1/8" angle. I added a couple of brackets to mount it to the box. There is a space between the box and the bracket for the trim panel to fit back in place. This helped make it stay pretty clean looking. The XS Power battery fit in there VERY snug. I dont think I have to worry about it sliding around at all. This has definitely helped with my power woes. No more dimming lights! YAAAYYY!!!!! I hope it helps my spl number too!!
lowpt Posted December 5, 2011 Author Report Posted December 5, 2011 Well, I went to a local comp yesterday. I was curious to see how the changes (battery and box volume) would effect my number. I gained almost 2db! I went from a 137.4 to a 139.2. I need to get some testing time in on a meter. I simply played what sounded the loudest to my ears. The 137 was @ 37hz and the 139 was@ 44hz. To explain the box volume change, the original size was 1.8^3ft. tuned to around 34hz. This sounded good overall and GREAT on rap music. It played pretty low and hit good at the lower frequencies. (Two shots was one of my favorite demo songs.) I took some bocks of MDF, glued and screwed them inside. I used enough to lower the volume to around 1.4^3 ft. This raised the port tuning to 37hz. It doesn't play the songs with the lows as well (still ok though) but it does a lot better on the rock/metal that I love so much. Like I said I want to get some time with a meter to tweak everything. I really want to see a 140+ out of this.
