bass_stalker Posted August 1, 2011 Report Posted August 1, 2011 i would like to have some opinions or tips for a double 18 build in a 2002 Chevy silverado. 1. should i use mdf or birch plywood. 2. should i do subs forward port up or subs forward port forward. etc 3. should i use one big amp or two smaller amps 4. should i do a double baffle or would alot of bracing be enough to negate a double baffle JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Brandon15zzz Posted August 1, 2011 Report Posted August 1, 2011 The funny thing is I have the same truck lol. 1. Whatever is cheaper both are effective. 2. I believe subs up port up would be best that's how mine will be. 3. 2 boards will be stronger then one most of the time. More boards also fights impedance rise. 4. I would just double baffle. But be sure to still do a lot of bracing. Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34 Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
bass_stalker Posted August 1, 2011 Author Report Posted August 1, 2011 The funny thing is I have the same truck lol. 1. Whatever is cheaper both are effective. 2. I believe subs up port up would be best that's how mine will be. 3. 2 boards will be stronger then one most of the time. More boards also fights impedance rise. 4. I would just double baffle. But be sure to still do a lot of bracing. let me be 100% sure on this. for a double baffle all i have to do is cut the holes the same size on both boards and then screw and glue them together? JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
kam311 Posted August 1, 2011 Report Posted August 1, 2011 Yes so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
bass_stalker Posted August 2, 2011 Author Report Posted August 2, 2011 The funny thing is I have the same truck lol. 1. Whatever is cheaper both are effective. 2. I believe subs up port up would be best that's how mine will be. 3. 2 boards will be stronger then one most of the time. More boards also fights impedance rise. 4. I would just double baffle. But be sure to still do a lot of bracing. hmm i guess hopefully i can flip the box to see which would be louder JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
