Mosin Posted August 2, 2011 Report Posted August 2, 2011 I don't know where else to put this. Sorry if in wrong place. HDMI cable I use is a standard Microsoft branded cable. Everytime I turn TV (Mitsu 65" 1080P, 120HZ) to HDMI-1, then turn on xbox it says invalid format then a sec later it works good. Its like theres a lag from xbox to tv. After the lag the Xbox start-up screen thing is already over. I've tried on my LCD with same lagging problem. Do I need to upgrade to say a "high speed" HDMI cable? I can't find the specs of this Microsoft HDMI cable anywhere. Can it support 120hz rr? I was looking into like Rocketfish brand HDMI cables Specifically this model This is the model of cable and features it has: RF-G1160 Connects an HDMI source device to another HDMI display device for excellent video and audio signals Delivers a 10.2 Gbps bandwidth for maximum performance Fully supports all HDMI features, including 1080p resolution, 120Hz screen refresh rate, deep color, x.v.Color, lossless audio for all formats and Lip Sync Back-twisted center conductors for superior data transfer and impedance control Mli>24K gold-plated connectors for maximum signal transfer and corrosion resistance Fully shielded, 360° enclosed metal connector shell for additional EMI and RFI protection 3-layer shielding for resistance to electromagnetic and radio frequency interference Protective connector covers keep dust and debris out while routing through walls. I'm just really annoyed with the lag. Thanks for any help. Derp.
BJD3 Posted August 2, 2011 Report Posted August 2, 2011 Any HDMI cable that says it supports 120 hz is fudging the truth. TVs do all the processing for 120 hz. Its all post-source processing. I don't think 3D TVs even require special cables, but don't quote me on that. I think the spec change for 3D was relatively minor, but I never really paid attention to 3D because it gives my brother and mother a headache. And I never wanted to be an early adopter for a technology I really don't care about. Honestly, while you may see a benefit from upgrading the cable to a later spec, all HDMI cables are equal assuming they don't fall apart. HDMI is digital, so you either get everything or nothing (or some middle ground where the picture is severely fucked, but you'd still likely notice it straight away). Basically, I think the current gen spec is 1.3a? Just go buy the cheapest HDMI 1.3a cable you can find. I like Monoprice. For once, Cnet gives good info... http://news.cnet.com/8301-17938_105-20056502-1/why-all-hdmi-cables-are-the-same/ Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
Mosin Posted August 11, 2011 Author Report Posted August 11, 2011 Thanks for the much needed info, BJD3. I went ahead and ordered the $5 Rocketfish brand HDMI cable from eBay, and when I swapped from the standard Microsoft brand it was totally diff. Picture was better and didn't lag anymore, and IMO the sound is better. Derp.
