VathanaKim Posted August 4, 2011 Report Posted August 4, 2011 lol sooo...... back over here haha Okay.... so as long as I correctly tune the amp then everything will be good? I am asking about this setup because I plan on eventually adding more amps but for now this will have to do. I am running a momphis mojo (rated for 1750 watts rms) on about 1k rms right now for about a month, and I haven't had a problem. Just make sure you set your gains correctly and check from time to time after you have been playing them at high volume to make sure the cone isn't too hot, if it is then your gains are probably not set correctly, or your electrical can't keep up and is causing clipping... Quote
paulgroce Posted August 4, 2011 Author Report Posted August 4, 2011 lol sooo...... back over here haha Okay.... so as long as I correctly tune the amp then everything will be good? I am asking about this setup because I plan on eventually adding more amps but for now this will have to do. I am running a momphis mojo (rated for 1750 watts rms) on about 1k rms right now for about a month, and I haven't had a problem. Just make sure you set your gains correctly and check from time to time after you have been playing them at high volume to make sure the cone isn't too hot, if it is then your gains are probably not set correctly, or your electrical can't keep up and is causing clipping... Okay awesome! Thanks a lot thats perfect info Quote Now: 2002 Mercury Mountaineer Pioneer AVH-P3300BT 250amp alt, "excessive amperage" Big 3 0gauge "kicker" KHC2000 Massive Audio N4 2x DC Xl Street wires 0 gauge Monster 402 speaker cable Future addition: 2x Massive Audio N4 2x KHC2000 1 KHC1800 under hood
BJD3 Posted August 4, 2011 Report Posted August 4, 2011 if you are just using a cheap hand held one, yes. but let me ask you this, when you have the bass turned up full tilt do you really care if there is a slight amount of distortion? could you ever actually hear it? wouldnt all the rattling panels be 100x worse? but this isnt a topic about the dd1 so lets not make it into one. In your substage could you hear the difference? Likely not. For low frequencies, don't you have to be at like 10% distortion or higher before most actually hear it? However, when talking about something like a midrange speaker or a tweeter, yes, I believe you would be able to tell the difference. Dudes over at Pulse could. Quote Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
