Tarball Posted August 6, 2011 Report Posted August 6, 2011 (edited) 1.5 cubes sealed sounds perfect. I would never put 4kw to a 15" sub in 2 cubes sealed ESPECIALLY one with a SHITTON of motor force, unless you like slamming softparts around. This is for an 18" sub though. Should be "OK". Build it and crank it..then let us know if you blow anything up! /Cheers ***Edited for typo. Edited August 6, 2011 by Tarball Quote CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
slow240sx Posted August 7, 2011 Author Report Posted August 7, 2011 ok, starting the build in a few minutes. ill take some pics and post it up. Wont be installed till next weekend cause im trying to find some power wire and nobody local has much good stuff. Quote 99 GMC Suburban 2 Death Penalty 21" 2 Crescendo BC2000 Boston GT-42 Amp 6 Selenium 6w4p 4 Crescendo tweets Hi output cs144 alt Audiocontrol Epic-160 Pioneer DVD head unit
Purplehaze Posted August 17, 2011 Report Posted August 17, 2011 Hey man, let me know how that works out for ya, I am very interested in doing a similar setup, but I was told Level 5's don't work well in a bandpass, or sealed box. Also, which side of the sub will be the sealed, and which will be ported? Not sure that it would make any difference, but I would think if the motor side was the ported side, that would help cool the sub? Like I said, I'm not real sure, just imo. Quote Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
