Chodes Heavy Chevy DC Build
from my experiance with a VERY similar truck ( 2WD version)
the back walls are VERY weak... i would brace it before putting a box in, i didnt and my back window seal is broken and the window is just flopping around..
subs forward port up seemed to work the best as well
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
^yep. :peepwall:
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
they are, i have basically the same truck but 2wd. All i did was fill the bar across with expanding foam, put padding between the metal and the plastic and then put dense foam between the back of the box and the back wall which held it in place and took all the rattle away.
cant wait to see this done.
edit: and tennis balls shoved between the truck bed and the back wall helps.
i just pl'ed 2x4s to mine and then filled any gaps with expanding foam.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Im currently in the process of doing that ^^^
Just need to find a way to hold 2x4s up
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
start at the bottom. glue the first one. let it dry and get solid. repeat the process. it takes awhile to accomplish though.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Howd you hold it tight to the wall?, i dont want it to come loose once i get the wall built and playin
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Nick. Never knew you planed on putting anything in this. These trucks tend to do good on the meter. At least from what I've seen they have. As stated above, be sure to take care of the weak spots in the back, kills sound and number. I'm gonna stay tuned to this one!
KwB
Team DC Audio Midwest captain
