I've been tinkering with Torres' calc, and I was wondering if anyone could check out the specs I have. The box is for two Kicker CVR 15s ('03 model) then eventually for two DC Lvl 3/4 15s. Box will be in place of my back seat in my truck and be subs up/port up (unless subs forward/port up or subs forward/port forward is better)
Box dimensions:
- 30" height x 40" width x 15" depth
Port dimensions:
- 13.5" height x 8" width x 20.5" depth (port up with 2 common port walls)
With the displacement of the two Kicker 15s, I should have 6.45 cu. ft. net vol with 16.75 sq. in. port area tuned at 36.93 Hz.
With the displacement of two DC LVL4 15s, I should have 6.31 cu. ft. net vol with 17.12 sq. in. port area tuned at 37.34 Hz.
With the displacement of two DC LVL3 15s, I should have 6.39 cu. ft. net vol with 16.90 sq. in. port area tuned at 37.10 Hz.
I can go as wide as 50", but I'd rather not go more than 30" tall or 15" deep.
I'd appreciate any criticism/comments, just no flaming. :P
Edited by Hikato
2012 Ford F150 XLT CrewCab w/ 3.5L EcoBoost V6
- Livernois Motorsports 93 Octane Performance Tune
- 6000k HIDs Hi/Lo + Fogs
- 5% Tint all around w/ 7" Brow (50% windshield soon)
- 6" BDS Suspension Lift + 2" Leveling Kit
- 35x12.50 Toyo Open Country M/Ts
- 20" Chrome Ballistic Jester Wheels
- 4" Heartthrob Exhaust
- Airraid Cold Air Intake
- Pioneer AVH-P4400BT
- 2x Sundown SA 10s in under-seat ported enclosure. (ports+subs forward)
- Rockford Fosgate T1000-1bdCP (T400-4 soon)
- Rockford Fosgate T1 6.5 Components
This box would also fit in the car I MIGHT be getting, that's why I was trying to keep it around what it's at now. If that would happen, I could face it port back subs back.
Don't do that, the back wall in a truck is not very rigid and will give a little instead of giving the sound something solid to bounce off of. Subs forward and port up has always worked well for me in ext cab trucks.
Edited by RAM_Designs
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
I will run the box subs up/forward port up in the truck, but the box would be tall, and would fit in a car. I'd put it subs back port back in the car's trunk.
I know the tuning is a little high, but would the box be safe for my needs?
Edited by Hikato
I agree with ram subs front port up or even down works well but def subs forward. Nice kidney punch
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
That box will be fine. It should sound good on everything @37 hertz. If you only listen to rap, I'd suggest tuning a few hertz lower, but either way It should work nice. Build a box to suit the application you're putting it in. Anything else may as well be called a prefab. A simple six sided box with no angles should take no more than 2 hours to cut/ assemble. Finishing work is really what takes up the time. Definitely go sub forward. What you do with the port varies from truck to truck.
Edited by Blackedout
