chevscalade209 Posted August 11, 2011 Report Posted August 11, 2011 i have desided to eaither put 2 18's or 3 15's in my truck iv been looking a t-line boxes,what makes them so great? im open to to anything to let me know what you think i should to 3 lvl3 15's or 2 lvl 4 18's and in what box 2 jl audio 12w3's sealed soon to be 4 level 3 15's blow through all dc audio
Namosh Posted August 11, 2011 Report Posted August 11, 2011 I doubt you have the room for a t-line with 3 15's. I had one with 2 15's that took up most of the bed of my truck. I'd say just go with a 4th or 6th order bandpass. My current box is 3 15's in a 4th order and it is the best sounding and the loudest I've ever had in my truck. My Ram Quad Cab Blow-through
AA98hoe Posted August 11, 2011 Report Posted August 11, 2011 What kind of truck and what amps? TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
chevscalade209 Posted August 12, 2011 Author Report Posted August 12, 2011 What kind of truck and what amps? its a 2000 silverado i think im goin to do lvl 4 18's and hifonics hfi2000d 2 jl audio 12w3's sealed soon to be 4 level 3 15's blow through all dc audio
g6ryder Posted August 13, 2011 Report Posted August 13, 2011 U need way more power don't cheap out on an amp www.wooferwarehouse.com
Sanitarium Posted August 13, 2011 Report Posted August 13, 2011 2 18's, see my first build log. There's no way you're getting a 3 sub t-line in your bed. T-lines are only great for low power setups as they offer a way to use the backwave of the sub constructively without any interference. IE if your'e gonna put real power too it, you need a suspension that makes even AQ subs look like floppy jokes. (it takes 2 hands to make a brand new AQ sub's cone move)
RAM_Designs Posted August 13, 2011 Report Posted August 13, 2011 Stick to a 4th order bandpass. Both subs you mentioned will work great. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
