I love linear power and t03 outputs reminds me of my first amp in the 80s a monolithic small footprint and wired it to .25 back then :-)
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
This one has the cleanest power of them all. Not saying the rest are bad but this is the best.
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
What's it rated at
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
It's so damn pretty... Specs?
2.2HV
2.2HV
Rated Power Output (4 Ohms stereo)
12.5 x 2
RMS Power Output (4 ohm stereo/4 ohm brgd) @ 12.5 volts
RMS Power Output (4 ohm stereo/4 ohm brgd) @ 14.4 volts
Maximum Peak Power (mono)
THD @ full output 20 - 20Khz
135 x 2/400 x 1
185 x 2/600 x 1
2 HP*
.004%
Slew Rate volt/microsecond
22V/ms
Damping Factor @ 4 ohms
>100
Channel separation
>72dB
Maximum current
4 ohms
35A
2 ohms
50A
Idle
1.2A
Fuse rating (AGU style)
40A
Dimensions:
3" x 9.5" x 12"
*HP=Horsepower a mechanical unit of power equal in the USA to 746 watts
Stock Everything
The New Setup
4 - RE Audio SX12D4
I had one years ago - a black one - sweet amp.
Hey Jacob. I remember you saying that on another site a while back I dont remember which one.
Stock Everything
The New Setup
4 - RE Audio SX12D4
