I have 2 Obsidian 15" dual 4's and i am now on an unexpected budget and am looking for an amp. I was originaly going to get a AQ 2200 but i dont have the money at the moment. I saw the power acoustik bamf 2000 and was wondering if it was any good and if it can actually put out 2000 watts? If you have any sugestions of an amp for around $250
No they do not do rated, the easiest way to find out is take the fusing in the amp * 12 volts * ~.75 (for 75% efficiency).
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
well if you like power acoustic and going by the 75% effincy then you would need a 2600watt amp to get 1950watts. which PA makes BAMF2600/2 http://www.poweracoustik.com/pa2011/amps-bamf-2600-2.html
Holy rockford copy batman!
OP- I would go with Crescendo if you are on a super tight budget. Anything less would be wasted money. I personally run AQ also, but if the budget is a big problem Crescendo is a great option.
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
Other well known budgetoptin AP 1800 D, them do rated, bassknob, ANL fuseholder with fuseholder included, or for 40 $ less the smaller AP 1500 D.
"them do" lolz..
Be sure them well known here in the forum as bang for the buck.
"in the abundance of water, the fool is thirsty" Bob Marley
