help with making speakers sound right
i just got a new amp and it sounds really good but i was wondering is there like a eualizer i can buy so i can make everything sound right? like my subs have bass but sometimes u can here other noises or it might pick up a high sound and sound werid. and my floor speakers put out bass but i had to turn the bass all the way down on my reciever cuz when its up it makes my subs sound weird. so my question is is there a cheap but good equalizer or somthing i can use? or any other options?
Depending on how much power you've got going to it, could determine WHY it sounds "weird" in the first place. When you say "weird", do you mean distortion, or clipping, bottoming out, or is the speaker just playing without a filter? And an equalizer is ALWAYS better than adjusting the tone from the receiver. I would definetly recommend getting an equalizer, even if you find the problem and fix it without one.
Bose = Buy other sound equipment.
i love the rattle it's the best part! i need louder cheap amp any ideas?
hi pass filter the speakers and low pass the subwoofer sounds like that would help most of your issues
im kind of noobish to this stuff but what is a high pass and a low pass?
and the weird sounding is ill be listening to a song and a deep bass line is going and a drum or kick hits and its really loud and annoying and makes all the bass cancel out like its trying to hit every sound in the song and it is running thru a pre out and i just got a new receiver and its helping allitle but still pretty bad still cant listen to old school hiphop on them the beats dont sound right ith the jumbled up bass from the drums :/
usually receivers have high and low pass filters built in. but i could be wrong.
to directly answer your question, a high pass filter is usually meant for mid/high range speakers (like 6.5" and smaller). it prevents said speakers from playing sounds below a set frequency. in other words, your smaller speakers will play the higher notes and won't play the really low notes.
the low pass filters do the exact opposite. they make sure your subwoofer doesn't play the higher notes.
essentially they work together to make sure each speaker is playing the right sounds.
it's somewhat difficult to diagnose the problem without being able to see what's happening for myself, but from what i hear, this may fix your problems.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
were could i find a low pass filter?
usually these questions are answered by google pretty well. but i came up with this. it seems to be the easiest route to go.
but before you go out spending your money, i'd like to know what equipment you're using. use links if possible.
usually the amp to power the sub will have a built in Crossover/LPF. if you have an external amp powering the sub, look for a knob or something resembling the top of a screw (there should actually be more than one) one of them will likely be labled 'LPF' or 'crossover freq' it should be marked with a couple numbers (usually 0 and 200). if this does in fact exist, turn it towards 0 and see if that solves the problem.
if that doesn't work, then you may have a bigger problem on your hands.
More box builds
