Ok editing my original post, I have almost completely cut out the fact that i have a trans issue. I took the s10 to autozone tonight to get the codes pulled and it came back a O2 sensor. The guy that pulled my codes has known me and has sold me all the parts for my last 3 vehicles. Works at a shop on his days off and said that more then likely it was a TPS or MAF
I hope you guys can help, My step dads 97 s10 (soon to be mine) is experiencing some problems. I will drive down the street fine but when i cruise i will notice that is will drop into passing gear and then back for no reason even tho i didnt get on the gas. Also noticed that the idle isa little off (truck does not have a tach) also some hard shifts
Let me clear this up, The truck shifts fine, NO slipping and goes into gear less the 1 second after i select it (yes i timed that shit) I have already replaced the fluid and said it looked red with a hint of brown. I was wrong because it was dark. That shit was bright red.
So does anyone have any experiences with this?
Is there a way to test it or do i just replace it?
Also my speedometer is acting weird to explain i took a video
Pull all the codes and check the fluid levels. I have heard that changing the trans fluid filter fixes alot of problems. Because if it is clogged then not enought fluid is getting through and providing enough pressure to shift correctly.
Big 3 with Yellow Top
Ill have to look into that
Just trying to get some general ideas of a few cheap things to try before i take it to a shop.
I know hwo you feel. I dropped the trans pan on my Ram a year or two ago to swap oil and filters. It was messier than all hell. But still cheaper than paying a shop. Check out some S10 forums and see if its a common problem that they know how to fix.
Actually thats what im doing now lol
Well went to auto-zone today and picked this up
Also it JUST accured to me that i quite possibly have a bad TPS
This video demonstrates exactly the same issue im having. Thank god for google.
Notice the spike in RPM's almost like its dropping into passing gear and then back down.
i have seen this problem a couple times in some friends whips. let us know if the filter and stop slip helps out..
WARNING: I speak 4 languages, profanity, English, sarcasm & real shit
2003 ford explorer
2 RF T1 D4 15s in a 6.8 cubic ft box
1 T1500.1bdcp
250amp ALT by Mike Singer
2 runs of 0 gauge
3 yellow tops
well with that video, it might have something to do with that person going 100+mph the whole time. LOL. but i have seen this problem a couple times in some friends whips. let us know if the filter and stop slip helps out..
Thats kilometers man....
hahaha gotcha man. its late, and i fail. :lol:
2003 ford explorer
1 T1500.1bdcp
2 runs of 0 gauge
3 yellow tops
Its all good, I just knew that a transmission issue doesn't happen like this overnight. Thats why i started looking around. Either way im changing the fluid it wont hurt, Then picking up a TPS.
  • Who's Online   1 Member, 0 Anonymous, 1034 Guests (See full list)
