FiJetta4 Posted August 17, 2011 Report Posted August 17, 2011 Hey! (first: Sorry for my english.) I`m building up my system for a couple of days and today I´ve tested it the first time. Details of the system: - 35mm² cable - gel battery 40Ah and 65Ah car battery - 10mm² speakerwire - 2x 100A fuses - Fi Audio SSD 18 - Hifonics Olympus The problem is my amp gets very very hot just after one minute.(about 80°C) The Fi has 2x 400w RMS @ 2x 2Ohms an my Olympus has 4x 250w RMS @ 1Ohm. I bridged it to 2x 500w @ 2Ohms. To avoid clipping I put both channels at 28V @ 50Hz [28V = sqrt(400W X 2 ohms)]. So the amp must be 200w rms underpowerd and the speaker should be fine.(all measurements were made with running motor for stable voltage) My Radio gives a clear signal and my Amp also. Everything works fine but the heat is just unnormal. The Amp is not under something, it layes open im my trunk. I hope someone can help me. Greetings from Germany
blownengine Posted August 17, 2011 Report Posted August 17, 2011 Is your ground solid to clean metal? 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
DTS909 Posted August 17, 2011 Report Posted August 17, 2011 Recheck your wiring sub to amp. VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
FiJetta4 Posted August 17, 2011 Author Report Posted August 17, 2011 Yes, I took the screw that nomaly holds the spare wheel.(spare wheel isn`t inside anymore) I think it should be a good ground. Can I measure it somehow?
skyhighcaraudio Posted August 17, 2011 Report Posted August 17, 2011 i had a friend come by who had the same problem and i took the volt tester to it and his batt said 13.6 when the car way on but when it hit the amp it was seeing 7.2 volts because he had grounded it to the spare tire bolt. not a bad issue to fix man just scrap the paint and primer off another spot and ground it there...or run it straight to the frame scrap the frame bear and ground it there or ground it to the batt if you have one back there (i didnt understand if the 45 or 65 amp hour batt was in back but if there is on ground it there) hope this helps Contact us for the best quality cables and accessories with the fastest shipping in the industry EMAIL: [email protected]<script data-cfhash='f9e31' type="text/javascript"> /* */</script> LIKE US ON FB: https://www.facebook.com/SkyHighCarAudio ADD ME ON FB: https://www.facebook.com/jon.rabe.1 MONSTER SKY HIGH/DC GMC: http://www.stevemeadedesigns.com/board/topic/127057-sky-high-monster-gmc-walk-through-12-lvl-5-15s-6-9ks-trim-panels-and-wiring-p-90/
FiJetta4 Posted August 17, 2011 Author Report Posted August 17, 2011 Hi, thanks for your reply. The 65Ah is in the front and the 40Ah is in the back. I measured directly at the amp and got 13,8V- 13,2V under load. Could it be that the amp is defective, but still works fine? =D
Ray Posted August 17, 2011 Report Posted August 17, 2011 The voice coil is dual 2ohm ? So the sub is 2- 2ohm loads? I noticed you said you were bridging a 2ohm load. Can you re-explain that for us. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
CleanSierra Posted August 17, 2011 Report Posted August 17, 2011 My guess is that he's wired at .5 ohm too ray Im not the one you want to try to troll. Just a fyi for you.
FiJetta4 Posted August 17, 2011 Author Report Posted August 17, 2011 Hey, the Subwoofer is a dualvoicecoil.(2 coils with each 2ohms) The amp has 4x 250w rms @ 1 ohm and I bridged it to 2x 500w rms @ 2Ohms. Each channel runns one coil at 2ohms.
skyhighcaraudio Posted August 17, 2011 Report Posted August 17, 2011 My guess is that he's wired at .5 ohm too ray very possible that would make a ton of sense as well let us know how you wired it and what ohm your sub is Contact us for the best quality cables and accessories with the fastest shipping in the industry EMAIL: [email protected]<script data-cfhash='f9e31' type="text/javascript"> /* */</script> LIKE US ON FB: https://www.facebook.com/SkyHighCarAudio ADD ME ON FB: https://www.facebook.com/jon.rabe.1 MONSTER SKY HIGH/DC GMC: http://www.stevemeadedesigns.com/board/topic/127057-sky-high-monster-gmc-walk-through-12-lvl-5-15s-6-9ks-trim-panels-and-wiring-p-90/
