Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
Peek-a-boo.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Forgot about the tribal decal.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Thanks to everyone for the helpful advice along the way.
Going to a local comp on Sept 18th. I will post the results when I get them.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Now I gotta change my avatar.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
There's a good chance your going to run into an issue with your kerfs. Given time, since you haven't fiberglassed the back side or even filled the kerfs with resin, chances are its going to split. I've seen it happen, and its part of the learning experience. I like to throw at least a couple coats of glass on the back side, or if I'm really lazy, I'll just do a large 45 over the back side of the kerf. You might get lucky, but it probably will fail eventually. Just something to know for next time. Box looks great though, contrasting black and white looks so sexy.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
I'm hoping the glue will hold. Not much power in there....yet.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Oh it was. First ported box and actually only second box I've ever built.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
