I was just looking in the XS catalog I have here and my Yellow Tops( The 2 sizes I can fit ) have better specs. CCA and AH
IMO even though the yellow top may have better specs, even "smaller" XS power batteries would probably way out perform the yellow tops.
Do you have any buddies with XS power batteries that you could try out?
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
No I dont.. Ill see what happens when I get the other one in tomorrow. If it doesnt help then will look into XS more. But for how much it would cost to change them out I could get the Rockford and run it a 2ohms and call it a day.
If it has low notes (usually not too "loud") then that can be drawing a lot of current.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
i would check how your volt meter is reading. is it placed at the front battery or at the back.
the closer the reading is to your amp the more accurate.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
