Current set up
EA 200 amp HO/ Big 3 in 1/0
Group 34 Yellow Top/front
Group 51 Yellow Top/back
Crescendo BC2000 at .5ohms
2 Alpine Type Rs( getting replaced soon by 2 Level 4s )
I have one more group 51 coming for the rear to make 2 trunk batteries total(132 AH total)
My Stinger multimeter is wired in with my HU and it drops much further then I felt it should. Even with nothing on it drops a .2/.3 at times. My Voltage control tops out at 13.8 but I cruise with nothing on at 13.6. It will drop to the 11s on some songs at interstate speeds. This is happening with the amp not even maxed out cause the Alpines only handle so much
What do I do next? Please help, I dont want to smoke this amp
Raise your impedance for daily use imo. :shrug:
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
The volt meter being on your headunit could be part of your problem. If the ground on your radio isn't perfect, it may not read the same voltage that your amps are actually seeing. Double check your voltage with a decent multimeter, at the amp. You may find better results.
Edited by Blackedout
Get less power. LMAO
Just playing. But yeah rise your impedance or up your electrical. And what batteries are you using?
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
Wire subs to 2 ohms instead of .5
Was the big 3 done?
try wiring you volt meter directly up to you battery.
Check with DMM for accuracy.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Do you know if your belts slipping?
Try tightening it, cuz once the belt starts slipping you basically get no output at all from your alt.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
Ill check that.. When it drops it doesnt stay there long, it pops right back up. Im hoping the 2nd trunk batt will help enough to get by until I can save for a T2500bdcp Ive been wanting. It should be in tomorrow
Hmmm XS power ftw?! Try one of their batteries out! You shouldn't have that much drop with a 200 amp alternator!
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
  • Who's Online   0 Members, 0 Anonymous, 942 Guests (See full list)
