I used my DD-1 to set the HU using the 0db tracks and got 43/50 then after that I went to the amp to set its gain I had it exactly like the directions but when I used the 40hz -10db track the DD-1 still didn't detect any distortion. Is this correct? Btw the amp is an Alpine pdx m12. I don't know if I did anything wrong or what is up. Any advice would be greatly appreciated. I also looked around the forum and didn't see any topic having a like situation.
Still didn't detect any when you turned up the gain? Make sure you didn't turn subsonic way up rather than down/off.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
did you try the -5?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
