HELP - Subs not loud
Hobbs155
If its aeros i would tune lower than youu think you want to so you can cut off the pipe as you are tuning till you find a tuning you like the shorter the pipe the higher the tuning. The main thing is that you cant put pipe back on, but you can take it off.
Edit: idk about daily use but on the TL those "elbows" to bend the pipe lower your score
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Mmm ok, because I read that the port should be one port diameter away from any thing, I think my box my be to shallow to fit a long port.
HU: Alpine CDA-9886 with Imprint Module
Fronts: Alpine SPR-60C
Rears: Alpine SPR-60
Amps: Alpine PDX4.150 and ICE Power 20000D
Subs: 1 x 15" Rockford T2D215
Big 3 Upgrade 0/1 AWG
2 Farad Cap
Wiring 2 AWG
120Amp ALT
external: 36cm x 38cm x 96.5cm
correct?
we don't have 3/4inch MDF in Australia (19mm) we have 18mm.
so internal is 32.4 x 34.8 x 45.5 per chamber.
meaning each chamber is 51 litre before displacement, which is a bit smaller than I would have done, but should be fine.
I'd tune to about 35Hz, as the chambers are smaller than ideal.
minimum a single 4inch port per chamber, which needs to be about 36cm long.
a 3inch diameter, 3.5inch long port would tune the box to like 45Hz :P
What would you say would be the ideal box for these subs? I have clearly messed up the first enclosure, It looks like putting in a 4" port that is 36cm long, is going to be too close to the back of the box.
2 Farad Cap
Wiring 2 AWG
120Amp ALT
At the moment i'm trying to use PVC pipe to get the correct lenght and tuning and then go out and buy proper aeros and cut them to the correct size. Do you think i'm going wrong here?
2 Farad Cap
Wiring 2 AWG
120Amp ALT
2 Farad Cap
Wiring 2 AWG
120Amp ALT
No you only have 2.99 sq in of port per cu ft . You need between 9-12 sq in of port. Youll prob need 3-4 ports. Ill put your dimensions in torres when i get home in a min. Im mobile rite now
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Is there any way to let some of your ports be external? That seems like the only way to make it happen. :(
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
2 Farad Cap
Wiring 2 AWG
120Amp ALT
  • Who's Online   0 Members, 0 Anonymous, 1072 Guests (See full list)
