Reptar Posted August 20, 2011 Report Share Posted August 20, 2011 Hi, been lurking for a long time but finally made an account today. I have a 2001 BMW 330i, and I wanted to buy a subwoofer. I've done my fair share of research, but I don't really understand the compatibility aspect. So, I was wondering if this Rockford Fosgate subwoofer would be compatible with this Rockford Fosgate amp. I would also like to know if there are any better alternatives, since I can't seem to find a review for this particular subwoofer. Thanks. Quote Link to comment Share on other sites More sharing options...
D-train-13k Posted August 20, 2011 Report Share Posted August 20, 2011 idk if that amp will handle the ohm load. its not rated at 1 ohm. but im sure because its a rockford and most of their stuff is pretty solid itll work. were you trying to stay in the whole rockford set up? or does mixing amps and subs matter Quote The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/ Link to comment Share on other sites More sharing options...
Leboy23 Posted August 20, 2011 Report Share Posted August 20, 2011 (edited) That amp doesn't show to be 1 ohm stable, inless I over looked. Maybe move up to the punch series 1000 Ninja'd Edited August 20, 2011 by Leboy23 Quote 2012 Nissan Altima SL DC M2 Lvl 3 12" with AR cone DC 1.2K Amp Kicker Sum8 Kicker 4 Gauge amp kit XS Power D2700 1.5 Cubic ft net tuned to 38Hz Link to comment Share on other sites More sharing options...
Reptar Posted August 20, 2011 Author Report Share Posted August 20, 2011 Could you suggest a better amp that can compliment that sub around $200? I am pretty inexperienced, and I really appreciate the quick replies. Quote Link to comment Share on other sites More sharing options...
D-train-13k Posted August 20, 2011 Report Share Posted August 20, 2011 Could you suggest a better amp that can compliment that sub around $200? I am pretty inexperienced, and I really appreciate the quick replies. this would work really well. its just a little over 200 but its a good price. Amp Quote The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/ Link to comment Share on other sites More sharing options...
Reptar Posted August 20, 2011 Author Report Share Posted August 20, 2011 Could you suggest a better amp that can compliment that sub around $200? I am pretty inexperienced, and I really appreciate the quick replies. this would work really well. its just a little over 200 but its a good price. Amp I haven't heard much about this brand, is it a pretty good one? I trust that you know what you're talking about. Quote Link to comment Share on other sites More sharing options...
Sanitarium Posted August 20, 2011 Report Share Posted August 20, 2011 (edited) That aq amp is great, that $350+ RF sub is way overpriced. Look into a sundown ssd series sub or something from fi. edit: autocorrect fail. Edited August 21, 2011 by Sanitarium Quote Link to comment Share on other sites More sharing options...
kwag415 Posted August 20, 2011 Report Share Posted August 20, 2011 Aq are Great Amps! Fosgates subs are pricy... ide look into the AQ HD series or maybe even a DC Level 4 12"? any one agree? Quote 2001 is300Headunit: JVC KD-X50BTHighs/Mids: StockHigh/Mids Amp: NASubwoofer: DC Audio LV4 12"Subwoofer Box: DLDesigns Box tuned to 32HzSubwoofer Amp: AQ 2200DElectrical: NA Performance:SRT Racing intake with ECUHKS Super Dragger 2BC Racing Coilovers BC 264 stage 2 cams full head build with BC Valves, Retainers, and springs Dezod Green Race Header Comming soon/Thinking about<p>Electrical: XS power under the hood (Suggestions Welcome)Performance: BC Cams,Cam gears, maybe GTE Swap down the lineMy YouTube Channel Subscribe and i'll return the favor!Xbox Live Team Website.My First Official Box Build.My FacebooK Link to comment Share on other sites More sharing options...
ryan916 Posted August 20, 2011 Report Share Posted August 20, 2011 (edited) Could you suggest a better amp that can compliment that sub around $200? I am pretty inexperienced, and I really appreciate the quick replies. this would work really well. its just a little over 200 but its a good price. Amp Idk about the 1200. The Rockford sub you want is rated at 700rms. It's a d2 so it can only be wired down to 1ohm or up to 4 ohm. the Aq puts out more than 1200 at 1 ohm and might be a good pair at 4 ohms with 570 watts. I think you would be better suited with an amp putting out 500-750 watts at 1ohm. At first i was thinking something like a sax125.2 bridged but that ends up being 400wrms@4ohm. Not bad considering its only $130 at db-r. But going back to AQ i think this is just perfect for your sub http://www.audioque.com/AQ750-Amplifier_p_46.html EDIT: If you're not set in stone with that sub, I would ask what is your budget, what kind of music do you listen to and what do you want out of your system? DO you want some smooth quality sound bass or do you want to turn it over full tilt and shake the cabin up? Edited August 20, 2011 by ryan916 Quote Link to comment Share on other sites More sharing options...
matt402 Posted August 20, 2011 Report Share Posted August 20, 2011 http://www.dcsoundlab.com/ Quote Link to comment Share on other sites More sharing options...
