Amp Guts Thread
TRTC360
  • 4 weeks later...
let's get some moar amp porn in here!
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Visonik V2908
2-channel amplifier
Total peak power: 2400 watts
RMS power:
2 ohms: 850 watts x 2 channels
4 ohms: 600 watts x 2 channels
4 ohms bridged: 1200 watts x 1 channels
Signal/noise ratio: >90dB
Channel separation: >60dB
Frequency response +/-0.5dB: 20 - 20kHz
Crossover frequency:
Low pass filter: 40 - 250Hz
High pass filter: 150 Hz
Bass boost: 45Hz 6dB
Fuse: 50A x 2
Dimensions (WxHxD): 12.20" x 2.17" x 39.37"
Next to a 1500rms amp
How many 1200rms amps look like this
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
Amp Name:
Stetsom 14k2d
Specs:
FEATURES V 14K2 D - 1 Ohm
Number of Channels: 1
WRMS Power (1 ohm) to 13.8 V: 16.200 Watts
WRMS Power (2 ohms) to 13.8 V: 11.200 Watts
WRMS power (4 ohms) to 13.8 V: 5.300 Watts
WRMS Power (1 ohm) to 12.6 V: 14.200 Watts
WRMS Power (2 ohms) to 12.6 V: 8.050 Watts
WRMS power (4 ohms) to 12.6 V: 4.350 Watts
Supply voltage: 9 to 15V
Pictures (required):
Time to rebuild.
TEAM DTF
Amp Name:
Digital Designs DD Z2
Specs:
1500x1@4ohms - 14.4v
6000x1@1ohm - 14.4v
8000x1@1ohm - 18v
Dimensions
32 L x 12 W x 2.76 H
Weight
56 lbs
Time to rebuild.
TEAM DTF
damn Rob thanks for those pics you have some beast amps right there :D
  • Who's Online   1 Member, 0 Anonymous, 919 Guests (See full list)
