Don't know how useful this information is but everyone ask how much of an output you gain from a ported enclosure vs a sealed one. Although these numbers don't directly relate to db's I recently switched out my sealed box for a ported one. All other equipment and settings remained the same so no other variables affected the test. Interpret them as you may.
This is 2 MTX TR7512 on a MTX JH600 amp.
(volume was not at absolute max clean because tones were at 0 db and I set the gains with a scope using a -4.6 db tone and did not want to reset them so I just turned the volume down a couple ticks)
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
so where as the box is tuned you experience the most rise in a ported box?
yes sir. impedance rise is highest around box tuning (for ported boxes of course)
What is the DB output at these various points? That is what you really want to know to answer the outpout gain question. This is intersting data though and can probably more accurately speak to the effiencies of sealed vs ported at the various freqs.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
No, in a ported enclosure you will have two impedance peaks and the tuning frequency is in between them.
Like this one would be tuned to ~31hz.
Wish I had a meter...I would do that for sure cuz as you said that is what would be more interesting is the db's.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
How louder was it to the ear?
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
This ported box is calculated to have 33 hz tuning but with the kerfed port there is no hard fact as to how much is effective port so that figure may be off just slightly... I used 1/2 the length. Also ported boxes peak usually 5-10 hz above the tuning freq. I have yet to get metered to see what the peak freq of vehicle or more so this "system" is. From listening to it I'm guessing around 45 Hz. Have had some say resonance freq of this vehicle is around that 45-48 Hz range. 2003 Bravada.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
