ChrisBell Posted August 24, 2011 Report Posted August 24, 2011 So I've finally decided to build my own trunk for my 4 subs, what kind of wood to get and what tools do I need? ( tools far as to cutting the sub holes etc.) Also what to get for holding the wood together? I have no experience at all in this area but I just want to be able to say I did my own work!
bassrace Posted August 24, 2011 Report Posted August 24, 2011 Mdf 3/4" or birch plywood 3/4" 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
bassrace Posted August 24, 2011 Report Posted August 24, 2011 A plunge router, tablesaw, jigsaw(if no router), screws, glue. Im sure i left some stuff out 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
RooTxBeeR Posted August 24, 2011 Report Posted August 24, 2011 Youtube how to build subwoofer box, theres one by some of the guys from rockford thats very detailed on everything as well as many others that will cover everything you need to know and do. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
tonedeaf Posted August 24, 2011 Report Posted August 24, 2011 Use lots of wood glue and wood clamps if you have them. Drill to pre-drill and for screws. Circular saw is nice to have for longer cuts, but you can use a jigsaw if you dont have a circular saw. Jig saw will do everything a circular will, just not as fast. You dont have to get a plunge router, many people, even some of the 'pros' still use jigs..so routers arent necessary, they just make it easier sometimes. Important thing is get a GOOD design. Once you have a design, check it again. After that, measure your trunk again, and make sure your design fits. When cutting the wood, measure twice. Then cut once. Straight edhes are your best friend. Nothing like getting it all cut and you realize nothing sits flush.
ChrisBell Posted August 24, 2011 Author Report Posted August 24, 2011 Use lots of wood glue and wood clamps if you have them. Drill to pre-drill and for screws. Circular saw is nice to have for longer cuts, but you can use a jigsaw if you dont have a circular saw. Jig saw will do everything a circular will, just not as fast. You dont have to get a plunge router, many people, even some of the 'pros' still use jigs..so routers arent necessary, they just make it easier sometimes. Important thing is get a GOOD design. Once you have a design, check it again. After that, measure your trunk again, and make sure your design fits. When cutting the wood, measure twice. Then cut once. Straight edhes are your best friend. Nothing like getting it all cut and you realize nothing sits flush. Thanx I my idea is to have 2 subs on on side of my trunk and 2 on the other side with 2 amps and cap in the middle instead of one big box, my trunk is big enough for it
