Box For Blowthrough
it's doable.
PM me your e-mail address and i'll send you the sketchup file to play around with/modify.
My question is. The middle subs look really close the the sides, would those be inverted? I'm thinking on use in AQ HDC315.
7.5" from front of baffle to that corner at it's closest point. just grows from there. sketchup is sent homie.
  • 3 weeks later...
it's doable.
I've decided to down size to only 4 - 15s. What would I have to do? I want to keep the same width and the height at 16.75''. I've never designed this type of box.
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
Damn youz good.
It's Sanitarium who designed this box. I'm still in the learning processes.
Youtube Channel
Here is my attempt at changing it to a four sub box... :ehh:
The measurements are similar to the same as above except a little shorter (15.25'' tall inside). The back opening is 14'' wide and the ''blowthrough'' part is 27'' wide. The back opening is 16'' from the back. I know it's a little tight height wise but they should fit with a little strengthening.
PLEASE HELP!
Youtube Channel
PLEASE HELP!
take your sketchup. draw a line accross the back of the port to block off the "chamber" right click and go to selction > area (or something like that) it'll give you the square inches. multiply that by height and you got your cubic inches. divide by 1728 (that's 12^3) and you got cubic feet.
Design looks solid!
  • Who's Online   1 Member, 0 Anonymous, 2176 Guests (See full list)
