Should be a simple fix. You can do it yourself, or send it to someone like db-r or tubenut and they can fix it pretty cheap I'm sure. Nice score.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
This is the oldschool 6ch amp not the 5ch amp, look it up read up on it you cant run this amp at 1ohm on any ch of this amp, you can only run this amp at 2ohm,
any idea what might have caused this?
vibration maybe or some one jamming a replacement fuse in
i noticed that the fuse was moving but i didnt think anything of it. so i played it and the fuse blew so im guessing since it was arcing there was too much resistance?
does anyone know what size fuses this needs? its got 4x 20 amps but online all the ones I've been seeing have 4x 30
yeah i knew that. it was only seeing a 4 ohm load when the fuse blew
