If you want to change the tone of your exhaust and Tennessee doesn't care about emissions testings, then cut off the cat and weld the glasspack in it's place and that should take care of it hopefully. I'd still recommend getting the tests done instead of throwing money at it and it doesn't fix a thing. I think my buddy went through $700 replacing all the sensors and not running any tests. I tested for vacuum, changed the cat and it was fixed! And he was pissed lol. Should be an easy and cheap fix man.
yeah man im getting tired of spending money and nothing working lol. but like i said i replaced the cat with a glasspack so i guess now i need to do a vacuum test?
Yea just get some tests run and hopefully they can find an easy cause to the problem.
hey sweet, another TN member! TN does care about having a cat, but depending on where you live it may not matter or not.
iv never been pulled over for it so i guess its all good lol
I'm in TN too haha. :drink40:
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
Yea you can check fuel pump operation, psi, and check all the seals around the fuel "spider injector" and make sure all of those "legs" off of the spider are clean.
Have you checked for error codes?
HEAD UNIT JENSEN VM9312
4 12" KICKER COMPS
4 PUNCH 150 AMPS "0NE ON EACH SUB"
2 ALPINE 3522 ON MIDS AND HIGHS
MLA MOD
BIG 3
OPTIMA D31T BATTERY UP FRONT, ANOTHER IN BACK
2 KINETIK BATTERIES IN BACK ALSO"ONE 800,ONE 1200"
DUAL ALTERNATORS "ONE 200 AMP" OTHER MECHMAN 270 LARGE CASE
Kinda sounds like your map sensor.jmo
4 12" KICKER COMPS
MLA MOD
BIG 3
  • Who's Online   1 Member, 0 Anonymous, 1817 Guests (See full list)
