OLDSKOOL78302 Posted August 27, 2011 Report Posted August 27, 2011 wait wait am i reading this right you took off the cat and put on a glasspack in its place?? if thats so then that is your problem. your truck is an 01 which means that its obdII. which means that there should be a pre cat and an after cat o2 sensor. since you took off the cat the after cat isnt seeing the right info which is making your truck run wayyyy rich which is making it bog down and backfire because the engine is getting way too much fuel. put a cat back on your truck and that should fix the problem. I forgot about that.That could be it to. HEAD UNIT JENSEN VM9312 4 12" KICKER COMPS 4 PUNCH 150 AMPS "0NE ON EACH SUB" 2 ALPINE 3522 ON MIDS AND HIGHS MLA MOD BIG 3 OPTIMA D31T BATTERY UP FRONT, ANOTHER IN BACK 2 KINETIK BATTERIES IN BACK ALSO"ONE 800,ONE 1200" DUAL ALTERNATORS "ONE 200 AMP" OTHER MECHMAN 270 LARGE CASE
theTank77 Posted August 27, 2011 Report Posted August 27, 2011 might i also suggest along with putting a cat back on your truck seafoaming your truck too http://www.youtube.com/watch?v=vRAV5ln5cUc if you dont know how watch the vid. seafoaming your truck will give it back some horsepower and will make it run smoother after its all done. just remember you have to change your oil no more than 100 miles after doing it my build log
EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 wait wait am i reading this right you took off the cat and put on a glasspack in its place?? if thats so then that is your problem. your truck is an 01 which means that its obdII. which means that there should be a pre cat and an after cat o2 sensor. since you took off the cat the after cat isnt seeing the right info which is making your truck run wayyyy rich which is making it bog down and backfire because the engine is getting way too much fuel. put a cat back on your truck and that should fix the problem. but it was acting up even before i replaced the cat?
vettedude102 Posted August 27, 2011 Report Posted August 27, 2011 If you check your oil and it looks milky you definitely need to change the oil. 2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette 2003 corvette z06 alpine radio and the bose system that came stock
vettedude102 Posted August 27, 2011 Report Posted August 27, 2011 another thing to check is see if its in time. 2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette 2003 corvette z06 alpine radio and the bose system that came stock
killallblue Posted August 27, 2011 Report Posted August 27, 2011 I will tell u were to go no offense but it the best place to trouble shot blazer forums and s10 forums both of them have s10s and slot of smart people
HatersGonnaHate Posted August 27, 2011 Report Posted August 27, 2011 I will tell u were to go no offense but it the best place to trouble shot blazer forums and s10 forums both of them have s10s and slot of smart people x2 They've probably come across this problem plenty of times. My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 I will tell u were to go no offense but it the best place to trouble shot blazer forums and s10 forums both of them have s10s and slot of smart people x2 They've probably come across this problem plenty of times. yeah im waiting for a reply from there lol
killallblue Posted August 27, 2011 Report Posted August 27, 2011 What's ur name on there lol thats were I am most of the time
just1moreamp Posted August 27, 2011 Report Posted August 27, 2011 wait wait am i reading this right you took off the cat and put on a glasspack in its place?? if thats so then that is your problem. your truck is an 01 which means that its obdII. which means that there should be a pre cat and an after cat o2 sensor. since you took off the cat the after cat isnt seeing the right info which is making your truck run wayyyy rich which is making it bog down and backfire because the engine is getting way too much fuel. put a cat back on your truck and that should fix the problem. I have a 2001-s10 truck and i cut out the cats and put pipe there and just put the o2-sensor back in the pipe and i have no code and it runs better than ever, when my truck was runing like that ended up puting fuelpump in it and changeing the pluges thay where fouled out, any way you do not have to have a cat on the truck 4it 2run right,
