Need Help with Voltage Drop!!
Ok, I got a DC power 270sp with a yellow top up front. Big 3 done in 1/0 Two runs of + and two runs of - to back batts. (Two 9a31 and one hc2000) two grounds in back. two runs of + & - 1/0 going to the amp. ( Memphis MoJo 4kw old model) Volts drop to high 11's low 12's..... What the "f" is I doing wrong??? PLZ HELP
Amp is wired to 1ohm
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Mids/Highs Amp-MB QUART ONX4.125
Mids/Highs- Undecided
Sub Amp-DC Audio 7.5
Subs-4x DC Audio xl 18s
Alt- 270sp & 250sp Dc Power
Big 3 1/0
http://dcaudio.us/
SPL-LAB sells rep. for IOWA
http://spllabusa.proboards.com/
IIRC these amps can pull like 600 amps of current each...not very efficient amps. 4k watts is no joke, but your electrical should probably keep up...id say your problem is amp efficiency mainly.
I know the amps are not very efficient,but F&*k. So how much electrical do one needs.. I was planning on running two of the Amps, at .67 each I'm going to need a lot more electrical.
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Big 3 1/0
http://dcaudio.us/
the 9a31 rest at 12.7/12.8 and the hc2000 and rest at 13
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Big 3 1/0
http://dcaudio.us/
Does this happen when driving around? The alternator puts out about 180 at idle, so if you aren't giving it the beans a bit then you won't be getting your full 270 out of it. Also, check your alternator, is there any black soot around the pulley on it? your belt could be slipping.
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
yes it is when driving around,I'll check the pulley.
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Big 3 1/0
http://dcaudio.us/
^^ That too. What about with the car on? You may want to try removing one battery from the bank at a time (still having two connected counting front) and see if you still have the issue, or if it gets better at all, or have all your batteries checked by autozone or the likes. But as I said..3 batteries isnt a lot. You have maybe 180 @ idle amperage. Then you have say 50 amps from the car. So your system from the alt is only seeing 130 amps...your batteries have to make up the difference. Three batteries wont make up for that 4-500 amps of power.
ok so more batts and maybe another alt. I was starting to think I had bad grounds, but I've Checked them time and time again. how many batts. should i have? think two more will cut it
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Big 3 1/0
http://dcaudio.us/
  • Who's Online   0 Members, 0 Anonymous, 1486 Guests (See full list)
