HotRodHam Posted August 28, 2011 Report Posted August 28, 2011 ok so im makin a fiber glass box for 4 12" AQ SDC2.0s (will ugrade some other time) i was wondering if its possible to put 1 big ass aero port right in the middle of the box and have the 4 12s go around it. so itd look like a + sign EDIT: will be making the box 9cuft 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
zx10intn Posted August 28, 2011 Report Posted August 28, 2011 depends really on the box itself. you have to make sure you have the depth to fit your aero in 1969 Chevy Chevelle 20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's Mechman 250amp cs144 alt w/AVBM Kinetik 1800 main battery/Kinetik 2400 in the trunk Pioneer AVH-3200dvd Headunit (2) sets of Hybrid Audio Technologies Imagine components up front (2) DD 3512's d4 coils Sundown sax100.4 component amp Sundown saz-3000d subwoofer amp 5ft^3 box tuned to 34hz MY BUILD
6berry Posted August 28, 2011 Report Posted August 28, 2011 it would have to have at least a 12" diameter but it would work 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
HotRodHam Posted August 28, 2011 Author Report Posted August 28, 2011 i tubbed out my tire well already. if i have a 15' long peice of pvc at my house thats 10-15"in diameter can i just cut it to size and put it in there? 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
zx10intn Posted August 28, 2011 Report Posted August 28, 2011 i tubbed out my tire well already. if i have a 15' long peice of pvc at my house thats 10-15"in diameter can i just cut it to size and put it in there? no, you can not just guess at both the diameter and length and put it in there. use a box calculator to figure out what you have going on, like torres calculator, because if you have built a 9cube ft box, after you put your port in it will no longer be 9 ft, and you will be lowering the internal volume drastically, maybe too much to be within specs of your subs ported recommendations 1969 Chevy Chevelle 20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's Mechman 250amp cs144 alt w/AVBM Kinetik 1800 main battery/Kinetik 2400 in the trunk Pioneer AVH-3200dvd Headunit (2) sets of Hybrid Audio Technologies Imagine components up front (2) DD 3512's d4 coils Sundown sax100.4 component amp Sundown saz-3000d subwoofer amp 5ft^3 box tuned to 34hz MY BUILD
HotRodHam Posted August 28, 2011 Author Report Posted August 28, 2011 no, you can not just guess at both the diameter and length and put it in there. use a box calculator to figure out what you have going on, like torres calculator, because if you have built a 9cube ft box, after you put your port in it will no longer be 9 ft, and you will be lowering the internal volume drastically, maybe too much to be within specs of your subs ported recommendations well i know that i was just saying would 1 big aeroport like that work right in the middle. after i figure displacement and port area 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
