ima be ordering 3 hid kits from ddmtuning soon
it says 55watt hig kits arnt recomended for small housing
just wanted an opinion if you think my escalade fog light housings are too small, if so what are the dangers?
2 jl audio 12w3's sealed
soon to be 4 level 3 15's
blow through
all dc audio
you should be fine. there is no difference in the bulb itself. the difference between 35watt and 55watt hids are the ballast. the ballast determens if its 35 or 55 watt. your housings should be fine. when you hook up your headlights be sure you hook it up so the low beams stay on when you hit your highs. if you have hids in your high beams it will take 3-7 seconds for the bulb to hit full brightness. having your low beams on will be a lot safer
I had 35 watt hids for my fogs and 55 watt for my high and low beams (that both work great) in my tahoe and even those got hot enough to separate the lens from the rest of the housing. Just my experience. If you can find them for your vehicle I'd suggest projector lens fog light housings that are suitable for hids
Edited by flashlight_65
You have to watch out if you have a plastic housing and lens because they will start to yellow from the heat. I have 35s in my fogs, so I know it will happen with 55s.
08 Tahoe
2 sets of JL Zr 650s
2 15" RE XXX(New)
DC 5k
thats what i would do ^ ^ ^ ^ dont want to risk it with the 55w.
with such a small housing running the 35w ones would be pushing it but it be better than the 55
