so my truck started running really hot the other day... i was like mfer sob pos and turned the heat on... which sucks cause its like 95 degrees here... so the temp went down. then it started blowing cold air...........
ok so long story short i replaced the thermostat filled radiator back up with anitfreeze and drove it around the block. all was good no leaks nothing.
today on my way to work it got hot again.... it touched the top of the heat gauge and went back down to normal once i just turned the vent on and not ac...
what could this be? would maybe a radiator flush help this???
thanks in advance
Pull the thermostat out completely and see what it does, it should stay relatively cold, def below the normal needle position. If the needle continues to fluctuate or stay hot with the thermostat out, than you may have a bad coolant temperature sensor. There might be an air bubble in your system which you could get rid of as easily as letting your engine cool down completely, pull your radiator cap and start the vehicle. With cap off and engine running squeeze the top hose which in effect is burping your cooling system, add coolant to the radiator as needed, making sure to use a 50/50 water coolant mixture. Of none of those help you may have a clog which needs to he professionally flushed/checked out.
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
What's the make and model?
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
What year is the vehicle? If it is post '96, there should be a plug under the driver side dash. Any flash tuner can read codes, too. SCT, Diablo, those type of things. If you take it to a shop, they will charge a stupid amount to plug it in and tell you whats wrong.
SMD Super Seller
My Feedback Thread
I'm gonno go with krypto at this point... does your thermostat housing have a bleeder screw? Or a return hose going back to the overflow pressure tank?
Kenwood KIV-BT900
Front Stage
RE 6.5 125.5.
Lanzar Max Pro 6.5
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
  • Who's Online   1 Member, 0 Anonymous, 2011 Guests (See full list)
