Which Port Would You Go With?
4 members have voted
  1. 1. Which Port Would Be Better...
    • L Shaped Slot Port, 8"x16.5"x51"
      1
    • Aero Port, 8"x17"
      3
Ok my question is... which of the 2 ports do you (in your opinion) think would be better...
CLASS: TRUNK
BOX: H 18", W 40", D 17", ⁴ft 5.69813...
SUBS: 2 15"s Soundstream Or DC...
Hz: 32
PORT 1: "L" Shaped Slot Port, W 8", H 16.5", L 51.48"...
PORT 2: Aero Port, D 8", L 17"...
Keep in mind ill be competing Amateur/Rookie... I'm not sure if that effects what kind of port I can have...
I have 5 tubes of 8" PVC pipe... I also have 6" but I want to go 8"...
Let me know what you guys think...
With the Pvc as a port you should flare each end. I would use a torch or heatgun and a stainless bowl thats the right size.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Your l-port doesn't have any air space left for subs and is tuned to 92 Hz before displacements and .68 cu ft after port displacement. Your Aeroport design is better but a little small on port area and with estimated displacement of just subs you are sitting at about 35 Hz. Net air space in the Aeroport box is a little under 5 cubes. Not enough air space IMO.
Yet again... rookie/amature/noob... idk what ur talking about wit the "l" port... I used the12volt.com's box/port calculators... so what did I do wrong?
:No:
If you are using a metal bowl, you are doing it wrong. If you want to flare PVC try this method:
http://www.subwoofer-builder.com/flares-25mm.htm
http://www.subwoofer-builder.com/flares-25mm-mold.htm
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
AFTER bracing, subwoofer, AND port displacements. A big L port eats into your net displacement in a big way. So shoot for like 9 cubes before any displacements. I'd seriously go with a couple nice 12's tuned around 34-35 and call it done in the space we know you have.
