Which Port Would You Go With?
4 members have voted
  1. 1. Which Port Would Be Better...
    • L Shaped Slot Port, 8"x16.5"x51"
      1
    • Aero Port, 8"x17"
      3
AFTER brcing, subwoofer, AND port displacements. A big L port eats into your net displacement in a big way. So shoot for like 9 cubes before any displacements. I'd seriously go with a couple nice 12's tuned around 34-35 and call it done in the space we know you have.
Well wouldn't the l port its self take the place of bracing along with the 45°s in the corners?
Posted (edited)
Your Width of 8" is way too wide for a slot port in that volume. I'm going to bed, maybe someone else can help. My advice is download the Torres calculator found in this forum and play with it yourself. It will give you much more accurate results. And the port ITSELF is inside the box so that decreases your volume. Try a width on your port of about 4 inches.
Edited by CleanSierra
I can get it up to 9⁴s by bringing my depth up to 26"... puts it at 9.00⁴ft
V
Your l-port doesn't have any air space left for subs and is tuned to 92 Hz before displacements and .68 cu ft after port displacement. Your Aeroport design is better but a little small on port area and with estimated displacement of just subs you are sitting at about 35 Hz. Net air space in the Aeroport box is a little under 5 cubes. Not enough air space IMO.
What if I got with the 6⁴ft and a Aero port? I'm thinking now about not going L port... but I love the way a L looks. Then again I can take my Aero n put my port outta the box
if you are bent on a L port go to http://reaudio.com/box.php and play with that
The RE calc is off quite a bit by what I'm told
Here's the torres calculator man if you can't find it. Torres Calculator
TEAM DC
www.dcsoundlab.com
2003 Tiburon GT V6 6 Speed
Ported Clam
6 12" DC Audio XL M2's
2 American Bass 1100.1
1 American Bass 350.4
3 D3100, 1 D975, 3 D925
Second Skin Damp Pro and Spectrum.
About 75% done
153.6 Sealed on dash at 34hz
  • Who's Online   0 Members, 0 Anonymous, 648 Guests (See full list)
