ninos306 Posted September 1, 2011 Report Posted September 1, 2011 quick question fellas. okay, so to add 1 extra battery in the trunk of a car/truck/suv whatever, all you need is 1 run of positive and 1 run of negative from the front battery to the rear. and then from the rear you can power your amp from that? or how does it work? example: xs d3400 in the front 1 postive and 1 negative run to the rear which would be a xs d3100 and then lets say a rockford bd2500 amp to be powered by that rear batt? thanks guys system is going to consist off 1 18' btl and a rockford bd 2500. Quote
Rockbrook Posted September 1, 2011 Report Posted September 1, 2011 Sounds good, but if i remember correctly, you'll want to fuse between your two batteries just in case something shorts out. Your vehicle wont go up in flames Quote
ninos306 Posted September 1, 2011 Author Report Posted September 1, 2011 sweet, thanks man. appreciate it. Quote
EBW Posted September 1, 2011 Report Posted September 1, 2011 (edited) Sounds good, but if i remember correctly, you'll want to fuse between your two batteries just in case something shorts out. Your vehicle wont go up in flames I do 2 fuses (ANL) 1 At the front one at the back so if theirs a short anywhere in between your covered. Edited September 1, 2011 by EBW Quote Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm
ninos306 Posted September 1, 2011 Author Report Posted September 1, 2011 now, were could you mount those fuses? just on the fender under the hood? Quote
shake n bass Posted September 1, 2011 Report Posted September 1, 2011 Sounds good, but if i remember correctly, you'll want to fuse between your two batteries just in case something shorts out. Your vehicle wont go up in flames yep fuse the batteries. you dont really have to run negative though cuz its ground to your car and engine so mostly run few grounds to body in back and its good. Quote 1996 dodge stratus audiopipe 3k 2 15 american bass xds 10 door speakers threw out car kenwood head unit. spl scores from trunk: 147.7db on 2k extreme out side window-129.2db kaos 3 min average music-138.3db
Rockbrook Posted September 1, 2011 Report Posted September 1, 2011 ok i have question, how do you figure out what size Fuse you need between your batteries? Quote
ninos306 Posted September 1, 2011 Author Report Posted September 1, 2011 Sounds good, but if i remember correctly, you'll want to fuse between your two batteries just in case something shorts out. Your vehicle wont go up in flames yep fuse the batteries. you dont really have to run negative though cuz its ground to your car and engine so mostly run few grounds to body in back and its good. really, no need for a negative run? Quote
EBW Posted September 1, 2011 Report Posted September 1, 2011 (edited) I run a neg back to the frame then a run from my amp/batt ground to frame at the same location. And 2 300 amp fuses should be good 1 up front one at rear batt Edited September 1, 2011 by EBW Quote Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm
ninos306 Posted September 1, 2011 Author Report Posted September 1, 2011 I run a neg back to the frame then a run from my amp/batt ground to frame at the same location. And 2 300 amp fuses should be good 1 up front one at rear batt so you run a negative wired from the front batt thats grounded in the rear of the vehicle, and you ground your amp and the rear batt to the same location? Quote
