and ive seen alot of threads were u can be a dick and others where you can be helpfull i have ideas thats why i ask i have went threw with some of the things ive asked i dont have alot of money so im rather limited thats why you see more ideas then actions would you like pics of my se's would that make you post something helpfull or?
arnt the stock xxx pretty bad ass as far as xmax goes anyway?
you dont want to spend a lot of money, yet you want a level 5 or 6 motor which costs probably a couple hundred dollars right there. and hes right, ive seen thread upon thread of you wanting to make a subwoofer, but you never do, even after all the help you've been given you could've probably made like 10 subs
edit: i also still fail to see why you absolutely need a woofer that can move a lot. since when does the amount of excursion the SOLE factor in how loud it will be?
Edited by Kranny
Why what are you thinking will happen by having a higher xmax? For one it will have horrible handling and more likely to have coil rock. Those are two reasons why I wouldn't want something like that, and there are a few others I can think of too, but you have to learn I guess.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Subs are engineered for a reason.
Sure there's a few people out there that can throw some parts together and have a great sub, but they all have a ton of experience working with subs that are already designed, or understand the engineering behind a speaker.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
I think he wants to do it cause it looks cool.
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
What people don't think of when they think "hi xmax" is the more a sub moves back and forth the longer stroke is ONLY good for very low frequencys. You can't do hi xmax on a mid to high frequency woofer. The time it takes a coil to move 1" is quicker than a 2" or 3" excursion. Like the xxx re subs the xmax is so high they only sound good below 25 hz or so( besides the smaller cone area models) . If your looking for sound quality don't bother.
Then why do I see a sq based sub with 30mm of xmax? And just because you throw a tall coil into the sub doesn't mean the motor will have the space and depth to allow such throw...thus major former damage and blown sub
Johns.jpgSuburban Coming Soon
SPL motors most likely wouldn't be good for a high xmax build. Since from what I know spl motors have extremely tight gaps, and high xmax subs typically use motors with "loose" gaps. And sounding good is usually user preference. user A might like subs that play tight high bass notes where others might like loud n low. Typically a sub with a high xmax can play lower notes louder. But may not be louder than another sub. I plan on building two 15s using ti baskets and 3hp motors with a lower fs and a relatively high xmax
