FS: AQ 1200D
Item:
AQ 1200D
Specifications:
Model AQ1200D
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V---16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,870X1 @ 2 ohm,1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Description/Condition:
Used, Works great, out side is a little rough maybe 6.5-7 out of 10
**I DO NOT HAVE THE BASS KNOB FOR THIS**
Price:
175 Shipped
Pictures:
Why such a low cosmetic rating? I (or should I say my friend) is extremely interested. That's a stupid low price.
Im trying to talk my wife into letting me spend my money, but shes a pita! If its still available in the next few weeks (which it prolly wont be) I will jump on it!
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
I try to rate things truthfully I based my rating on the spot on the face of the amp and the rub marks on the front of the amp on the bottom set of heat sinks. I would rather have someone get an amp and say this looks better than I thought vs. Man this is beat to crap.
