How many switches would I need if I just wanted front back side 2 side and what causes a airbag to blow and are they very easy to fix, if popped.
Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
In a f,b,s,s set up you usually want to run a switch box with multiple switches. I use a 7 switch box (front, back, pancake and individule corners). There are 9 and 10 switch boxes available, too. They will add side to side and see saw switches.
  • 1 month later...
  • 5 weeks later...
how long does S.S. bags last if kept up right and has anyone seen a 96 camry on airbags or have a diagram for installing airbags on a 96 toyota camry.
  • 3 months later...
i had some firestone bags I was the 3rd owner. about 12 years on them and they are still good. I changed them just to go the slam bags.
1st  SMD "System of the Month" Feb. 2007
Zapco Studio 500 (2)
Zapco Studio 300X
Zapco Studio 204 (2)
(2) FI 12ssd's w/ copper coils
DLS Iridium Tweeters
DLS UR2.5 MidRange
FI. N.7 Midbass
JL Audio TWK 88
Mechman 370A Elite Alternator
I dont recommend making your own switch boxes unless you know what your doing. Theres a ton of switch boxes out there. So making your own is kinda pointless. Unless its custom. I use the avs rocker box with the extra relays. Its assembled well and easy to control. It also can be locked so no one can hit your switches. Its nice to not have to worrie about something braking on you and leaving you stranded.
http://www.bagginit.com/ Is a great resource for air ride questions and answers.
Hope that helps.
I bought a $4 hobby box from Rat Shack, drilled 10 holes and called it a day. B)
  • 2 months later...
Anyone know what Brackets I need for the brackets for my car, 1996 toyota camry.I got everything down.
  • Who's Online   0 Members, 0 Anonymous, 1346 Guests (See full list)
