Need help!!!!
A fuse tap would be a much better idea, I just dont know where to get them, so I totally spaced on that idea.
But there should be a ground in your GM035 harness.
Let me know man, if you cant get it. I can deff. get some pics for you soon on some ideas.
And once you get a build log up, Ill check that out too.
If you want, I have three links of work Ive done in my sig, you can check those out and let me know what you think.
Would system control wire do fine? I saw some of the stuff you do for friends and it looks very very nice! :drinks:
Thanks man!
Let me know when your log gets up and going.
what do you mean a terminal for the ground are you trying to ground inside the fuse panel??? when i said run the wire over there too i meant only if there was part of the frame available for you to ground to not to try and ground inside the fuse panel.
A terminal to hook the ground to a bolt
http://www.youtube.c...er/SmallTownSPL
2002 Chevy Blazer
Substage: Shhh, its a secret ;)
Mids and Highs: Stock-Going to change soon
Amp:MTX 92001
Wire:1/0 Welding cable
Electrical:Stock
http://www.stevemead...__fromsearch__1
I hope she was meaning that to you. Any who.... You dont say you wanna have dinner in the first damn post. talk to her first. I say find out if the status was torwards you..
Here try this...
"Hey hows it going :)( notice smiley face makes everything better ) I saw your status. "You are far from usual".... So is my dick... Wanna Fuck tommorow???"
Or send her message saying "hey" she replies back "hey" when this happens reply Wanna fuck (INSERT ADDRESS HERE)
Quote of the SPL Creed ; back in the day my girlfriend gave me a choice between her and my love for car audio, I told that bitch I've made harder decisions at the Coke machine. :)
So all i need to do is connect the radio ground to the harness ground?
2002 Chevy Blazer
Amp:MTX 92001
Electrical:Stock
Here try this...
I installed all my wires color coated as you should, except the acc wire. I ran the acc wire down behind my fuse panel(which im assuming is on the driver side of the dash between the door and dash) found a fuse to wire adapter i think at napa. Wired it to the fuse adapter and voila. No showing wires no wedging wire into a fuse slot good old fashion clean wired.
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
Yeah, thats the way to do it man. Cant believe I forgot about those fuse taps. Haha
All done, my dad ended up figuring it out. Didn't need to run an ACC wire just had to ground it to before the capaciter.
2002 Chevy Blazer
Amp:MTX 92001
Electrical:Stock
Here try this...
  • Who's Online   1 Member, 0 Anonymous, 1499 Guests (See full list)
