I have installed LED lights in the footwells of mine and a few of my friends' cars. We have all just used a simple on/off switch but I would like it to play to the bass. After reading the reviews on some vibration detectors, Ive scratched that idea out since my system is fairly loud. My amplifier is 1500 Watts so I can't hook them up to it. Te only idea I have come up with is buying a really cheap and weak amplifier from ebay or some place, run an RCA from my sub amp to the little amp, minimize the little amps output power, and run the LEDs to the speaker connections. Will this work? Is there a better way? Please help. Thanks.
1997 Dodge Ram 1500 Ext. Cab Build
(2) Rockford Fosgate T0D412s
3.7 cubic foot ported box
(1) Rockford Fosgate T2652-S
(1) Rockford Fosgate T152
Pioneer AppRadio SPH-DA02
Clarion EQS746 Equalizer
Hifonics HFi1500D
Hifonics ZXi80.4
Custom Dash Bezel to hold Double DIN
Custom amp rack w/ cooling fans
Second Skin throughout entire truck
Optima red top battery
AudioTechnix wiring
You can't hook up LED's to an amp through the speaker input, and have it flash to the music.
The best thing to do is buy something like that^^.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
dont know exactly what u mean but.....the easiest way would be to get something like this :good:
http://www.crutchfield.com/S-70j9sZBkNw2/p_546ANMI2/StreetGlow-ANMI2-Musical-Interface.html
Do You know where i could get something like that? Crutchfield no longer carries it.
Hifonics HFi1500D
Hifonics ZXi80.4
AudioTechnix wiring
I always wondered how this worked but never looked into it. When trying to understand it I assumed it has to be in some sort of active setup with some sort of logic chip analyzing the freq's of the music. For example, if the output freq was say 30-60 hz the led would be powered etc. That device doesn't explain it, but I just figured that's how it worked.
I have one of those and its hooked upto the neons under my truck too.
How it works is the button on the left activates the sound sensitive part You can turn it on so it flashes to music or you can turn them on solid. Them middle knob lets you adjust it to were you want it to pick up the sound. Its not so much you tune it to a certain freq I think its more due to the vibrations that sets off the flasher. The button on the right is just a basic on off switch.
that ^^^^^
it works with vibrations, like mentioned
theres a few places that have it, id try ebay aswell
sorry to steal thread lol....WHERE IN THE WORLD DID YOU GET SQUARE HALOS????
