We tested in a burp car and found the Soundigital to be quite a bit more efficient.
Car is a CRX with 1 batcap 4000 and 2 DD 9512 loaded at .5
Voltage drop the Sd is the clear winner, score wise...
155.1 Soundigital 16k
154.4 DC 12.0
153.2 DD M4a
Burp wise the clear winner was the SD.
FWIW... all 3 amp's are no joke. This is not by any means scientific, just a few buddies hangin out who wanted to know how each amp would do.
Edited by Team SSC - Dan
Team SSC
Team DD
as far as rating goes it should be no surprise that it does higher numbers than the others.
3 times the power of the DD
another third of the DC
edited for keeping it honest.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Nice but what plays music the best dan?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
We have had numerous 16k amps with no issues.
FWIW soundigital is a partner on SMD let's not forget.
In my heart I would never use the 16k in anything but a spl car.
FWIW The DD and the DC are very solid units. FWIW the DD is mine. Trust me I wanted it to win.
How dirty u take out your haterade comments...
NEXT TIME WE WON'T SHARE RESULTS
Team SSC
Team DD
i edited my post hope your happy.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
if you want me to keep my comments in there I would. since you got bent out of shape I figured id help you. make up your mind
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
lol at you 2.
i love it when i see threads like these, with side by side comparisons. wish there were more. also wish you guys clamped the amps. when i saw big power amplifier numbers, i thought there were gonna be clamped power results
Alpine CDA-9886Hertz Mille 3 ways active
Hertz SPL Show 8's
2 Audison Voce Quattro's2 DC Audio M2 Level 5 12'sDC Audio 12.0KKnuKonceptz Wiring4 XS Power D3100'sDC Power 390XPSecond Skin Damplifier Pro and Dynamat Xtreme
This thread is purely about numbers, SPL...
Although my comments clearly show I would not use the 16k everyday.
Again just 3 guys that believe in their amps, sucks mine was the quietest!
on the clamped numbers, all results aren't being published. Probably going to get chewed out for even letting that much out.
Team SSC
Team DD
  • Who's Online   0 Members, 0 Anonymous, 716 Guests (See full list)
