Voltage issues please help!
my voltage is randomly dropping while driving. I usually play my system at about half volume.
big 3 is done in 4 gauge.. I didn't have any 0 gauge at the time. I do plan on upgrading to 0 gauge
alternator is stock
the only battery I have is an optima yellow top under the hood
my question is, should I get a bigger alternator or another battery?
Ideally I would get 2 XS D3100s and a 325 amp singer alternator but money is an issue.
System is in my sig
Edited by infamous360
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
How low is your voltage dropping?
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
and what car with stock alt size.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
its a 2006 hummer h3. alt is 100 amps i think. im running about 1100 watts rms (amp + hu) at 1 ohm
it usually drops to the mid 11s and a few times the entire stereo cut off for a few seconds
edit: man I cant type today =(
whats your battery resting voltage you may have a bad cell.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
get your resting voltage up. thats not good. 12.8 or higher.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
ok. the battery is old so ill just replace it with an XS power and probably put a small XS (D975) in the back
EDIT: Forgot to say thanks. so THANKS!
  • Who's Online   1 Member, 0 Anonymous, 994 Guests (See full list)
