bmph8er Posted September 8, 2011 Report Posted September 8, 2011 im going to be running 2 stock alts. (mostly cuz its free) and i was wondering if this was enuff belt wrap to keep it from slipping. i figured a stock 85 amp alt should be good. that do you guys think ignore all the crap u see wrong with the 2.8 i just got the truck from someone who didnt know how to work on stuff 2001 gmc seirra 5.3 auto 3.73 locked rear, long tube headers, offroad y pipe, duals, cai, black bear tune, 2/4 drop, 22s, rockford fosgate mods and highs and 4 ab hd 15s and a ab 750.1 1995 civic 1.5 auto slower then hell, dropped on coil overs, ex hub caps, 2 12 trunk, have 450 bucks in the car and gets 35 mpg 1992 s10 being bagged, shaved, and small stereo. right now a pile of parts
n8ball2013 Posted September 8, 2011 Report Posted September 8, 2011 It leaves me going ehhhhh. which means probably not. this is the wrap on mine and i still have slight slip. I think its a bad pulley though. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
AA98hoe Posted September 8, 2011 Report Posted September 8, 2011 I had the irragi and it slipped now I have the dc and it slips too both under heavy load or when tranny shifts. Op you need more wrap TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
bmph8er Posted September 8, 2011 Author Report Posted September 8, 2011 hmmm ill have to try and see what happens. im hoping since its only a 85 amp alt it may not have tthhaatt much drag. i guess if it does slip i can always change it. i dont actually have a big stereo or anything so there shouldnt be a large draw on the alts. i only really did it for the hell of it and make sure my 2 viair 444s have enuff voltage. so max drag is prolly 55 or 60 amp plus truck. so i hope itll work ill keep my fingers crossed lol 2001 gmc seirra 5.3 auto 3.73 locked rear, long tube headers, offroad y pipe, duals, cai, black bear tune, 2/4 drop, 22s, rockford fosgate mods and highs and 4 ab hd 15s and a ab 750.1 1995 civic 1.5 auto slower then hell, dropped on coil overs, ex hub caps, 2 12 trunk, have 450 bucks in the car and gets 35 mpg 1992 s10 being bagged, shaved, and small stereo. right now a pile of parts
techforce Posted September 8, 2011 Report Posted September 8, 2011 Being those are stock and it does not take much to produce 80 amps... It MIGHT be ok as long as the belt is soft... You might need a lil belt dressing to keep the belt soft... N8... I think that because the wrap on the one is so long, (the tensioner so far away) that the belt stretches and it slips... (The other needs more wrap period) but, you gotta make use of what room you got tho...
Pauliesnite93 Posted September 8, 2011 Report Posted September 8, 2011 so thats what it is when my truck shifts at full throttle. belt slip. is a bad squeeking sound Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up
techforce Posted September 8, 2011 Report Posted September 8, 2011 Yeah, it is possible that when it shifts, it slips, when the RPMs and the load on the engine change, so does the tension on the tensioner...
