Posted (edited)
ok so i have a 2006 honda pilot and its gutted out right now no audio equipment hooked up at this momment only the headunit.. i have a d3400 in the front and a d3100 in the back (not hooked up) and charging it i have a dc power 320amp alt.. i installed my stinger volt meter yesterday.. so i was driving today and i noticed im charging at only 14.1 - 14.2 and while i was driving the voltage dropped to 12.9 - 13.1 i was like wtf.. so i stopped the car pulled out my dmm and it jumped back up to 14.18 - 14.21.. so im confused what do yall think is going on.. ive talked to dc power about adding the 15.1 regulator on it so i have to send it in but i just noticed this issue.. can anyone help please??
thanks durrani
Edited by durranic
MURDERD HONDA PILOT!
im sure you calibrated your voltmeter correct?
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Same thing happens on my Civic. Driving along @ 14.6, it'll drop to 13 with no music playing, and if I introduce another load on the system like a turn signal, power windows, headlights, it'll jump back up to 14.6. I'm pretty sure it has something to do with the regulated voltage at the computer, not the alternator.
well i actually didnt calibrate it myself.. but i did check it side by side with my dmm on my d3100 thats not hooked up and it was reading fine with the dmm.. so im guessing its okay!?
yeah i did notice that.. cause as soon as i flipped the turning signal the voltage popped right back up.. so you think its a honda thing??? and another question y is my voltage sitting so low? i know its not that low but i would love to be at like 14.6 lol
It's most likely the ELD..... Which is a Honda thing. Google it and read up on it, it regulates the voltage so the alternator doesn't work more than it needs to, and that helps to improve gas mileage. I think there might be a bypass for it, but I'm not really sure.
its probley like my mustang since
When you have a load, you will have higher voltage(then will be compensated at the same time and drop due to current demand)
Your vehicle isn't "stupid", you are just wanting a higher voltage when there is no high load and it's not necessary all the time.
make sense?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
thanks will look it up!!
make sense?
ahh i got you.. dc power was also telling me that the 15.1 regulator that i want on there may or may not make a difference in my voltage charge because of it being a honda and i guess honda comps are a bit picky..
