Well RF had a stupid idea with this rubber that covers where you screw the sub into the box. For one its a slot ported box with plexi glass, so its a b#$%# to get a screwdriver in there. I did this trying to take one of the screws out, I know it is small but it still scares me. What would be the best approach to repairing this little hole.
Uploaded with ImageShack.us
2000 White Saturn SL2
Kenwood KDC-248U Head Unit
1 Rockrod Fosgate HX2 punch DVC 12
1 Rockford Fosgate R500-1 amp
Stock Mids & Highs.
Budget Build, I spent about 330$ for the setup.
but its a crx, if you cant fart and do a 150 in a crx there is something wrong...
ive seen people use silicon not sure how long it lasts tho . and dont be hard on your self almost everyone does this at some point
REP
It isn't the first time. Every time it's happened was in a bandpass enclosure. What about gasket maker? It is called ultra copper sensor-safe high temperature silicone gasket maker. It's make by permatex.
Stock Mids & Highs.
Use some "Amazing Goop" brand or 3M brand Windo-Weld. Not all silicones will stick as well. Don't glob it on, apply a few light layers.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
I put some of that gasket maker on, it seems to be sticking fairly well. It seems "oily" leaves like a residue when you wipe it off. I am so pissed at myself right now >.< grrrr. I just got this sub today. I wanted to take the sub out to put some better wiring in the box. I applied one thin layer on the outside and took my finger and rubbed some on the inside. I'll see how it holds up i guess.
Edited by Maroon97SL
Stock Mids & Highs.
How serious is this? like honestly What would be the worse case scenario? I will be pushing the sub with a RF prime R500-1 amp. The sub is a 1000 Watt @ 4ohms DVC 12" HX2 RF
Stock Mids & Highs.
Worse thing would probably be the hole getting bigger. If it messes up I can probably sell you a 10" hx2
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
I don't have any more money for subs. Its dual 4ohms
Stock Mids & Highs.
  • Who's Online   0 Members, 0 Anonymous, 732 Guests (See full list)
